Cobra intake and N2O?
This should get you there.
http://www.barrygrant.com/nitrous/default.aspx?page=94
If i was you, i would get a dry kit for 250 used. it will save you the money. and the intake doesnt matter too much with nitrous, i would be more concerned with the heads and cam.
That Barry Grant t-body plate looks good.
Either way,if you gonna spray over 125hp,consider a bigger fuel pump (for wet kits) and injectors also (if you get a dry kit,you dont need larger injectors with a wet kit,because the nitrous system will supply the extra fuel).
