cobra intake
More info :shrug: :shrug:
Both intakes are better depending upon what is done w/ the car and what you want to do w/ the car.
You cant just compare two parts and have a direct answer for what is better, its the same way w/ every part.
new to site. just did the profile and put what i have done already. not sure if it will show it so here it is. 95 gt stock motor. c&l mass air kit,pulleys,65mm tb, shorty headers,prochamber,cat back.i dont go to the track so its basicly daily driver.i will start goin to the track soon. next i want to do the intake. i basily just wanted to know if the profesional products was a POS. the 65 tb i have now is.i just ordered a 70mm bbk. thanks,greg
well if you only plan on the intake for a while to go with your current mods then the cobra would be a better idea.
if you had plans for new heads and cam then the prof prod intake (same cast as the edelbrock) would be a better idea, but you may lose some low end grunt with a mostly stock engine
Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search
what about running rich.my car stinks(well i dont really mind it but my mom and bro say that). I put the 24lb injectors on.will it even out when i do the intake.i also think my timing is off because it backfireing a lil bit. I think i need a new drive shaft.if i get on it it kinda grinds a lil bit.Im going to bring it in soon.im not a mechanic but i did most of the mods myself.except the headers back.my buddies that work on bikes did it for me.i was going to also get the gears.i figure i might as well get it all done when i bring it in.i was thinkin aluminum driveshaft,what gears?
