  • SN95 4.6L Mustang Tech
COBRA OR AVIATOR?
  • Thread starter Thread starter 99SuperSnake
  • Start date Start date Aug 1, 2004
9
99SuperSnake
21
Friendswood, Texas
Aug 1, 2004
  • Aug 1, 2004
My car runs really rough when its in boost... im pretty sure the problem is my fuel delivery, im runnin 42lb injectors with the Walbro 255lph fuel pump.
I need some suggestions on which fuel fuel pump i should go with to support more horsepower, and hopefully smooth the car out some.
stangman
2,690
10
69
in a 3 bed, 2 bath
Aug 1, 2004
  • Aug 1, 2004
if it were me i'd get the cobra tank & pumps
Beau
3,050
San Diego
Aug 1, 2004
  • Aug 1, 2004
you're running a walbro and 42 lb injectors and you're having problems with only 10 PSI?
why not just get an inline boost pump?
9
99SuperSnake
21
Friendswood, Texas
Aug 6, 2004
  • Aug 6, 2004
What kind of Boost pump would you recommend?
The car is very jumpy, not very smooth....
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Aug 6, 2004
  • Aug 6, 2004
get rid of that Walboro pump ASAP!!!!!
it's not designed for the returnless fuel system and can die without warning.
the Aviator pump will be fine. it will work and be somewhat cheap.
the Cobra tank is better because of the baffles. but it's more expensive.
9
99SuperSnake
21
Friendswood, Texas
Aug 7, 2004
  • Aug 7, 2004
i appreciate the help
showstopper2
425
New Bedford, Ma.
Aug 7, 2004
  • Aug 7, 2004
aviator pump here and over 400rwhp with knock on wood no problems at all so far. under $200 for it versus around $700 for the cobra setup.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
  • Mindseye007
  • Aug 16, 2026
Mindseye007
