Cobra supercharger on a 98 gt?
MyEarsHurt
918
I have a 98 gt stang, and I was thinking about getting an eaton supercharger off of a 2003 cobra. My question is this, would it fit? What would I need other than the supercharger? New fuel injectors? Fuel Pump? ECU flashed? I just really dont know, and need some guidance. But my main question is will that supercharger fit on my 4.6 gt from 98. Thanks for the help.
You'd obviously need a new intake to fit the blower on since it's roots type, or is it a screw type SC? Either way if you got the blower and intake off of the cobra you wouldn't be able to fit them together without an adapter plate. Better off in my opinion to get a kit made for the 2v.
no it will not fit unless you can make an adapter. the 2v 4.6's intake ports are farther apart than the 4v ones. once you figure out the adapter, you would need new injectors, fuel pump, belt, new ecu or reflash. you definately will need a good dyno tune. i think it would be easier for you to just get a roots or a twin screw (the eaton is a roots) that is designed for a 2v.
