code 0175 bank 2 rich. Any ideas?
i would presume this code to come on while boosting. are you running a FMU or how are you adding additional fuel while under boost.
a leaky injector could as well be the cause. usually when these go bad, you would feel the misfire as well.
I had the car tuned yesterday and the tuner said that he cant change the fuel from bank to bank. There is no air leaks anywhere because I have a vac/boost guage. Can a fuel injector get leaky? How can I check injectors or coil packs?
Thanks
