CODE 10 40 please help
  • Thread starter Thread starter robby94gt
  • Start date Start date May 1, 2006
R
robby94gt
  • May 1, 2006
Pulling code 10, 40,I know that means 1cyl and 4 cyl has a problem but what I is the cause of it .
Car was running so bad bogging and surging, bucking, bad idle all the good stuff. so I found that the fuel pump was bad putting out 26 on the gage, at its best, got a new one and new fuel reg now putting out 39 . tbs is set at .99 put new cap on accel and nothing got any better. The only change it actually stalls completely now any thing I should be doing or something I missed please help I am not able to stop I am obsessed with getting it running strong and properly .
I am grateful for any help
Rob
MysteryMachine
1,835
Parkesburg, PA
May 1, 2006
  • May 1, 2006
no offense but ya'll thought i wrote and spelled bad
R
robby94gt
  • May 1, 2006
SORRY
MysteryMachine
1,835
Parkesburg, PA
May 1, 2006
  • May 1, 2006
1. when you did the plug wires did you put them on right?
2. Have you checked your plugs
HISSIN50
34
129
May 2, 2006
  • May 2, 2006
If you are spitting codes for those cylinders from a CBT, I would check the quality of the spark for those cylinders. I use an inductive timing light and check the strobing for any burps, etc. Pull the plug and check it for gap erosion or other weirdness. A noid light can be used to check for injector pulsing electrical feed.
If you ran the CBT, did you let it test all 3 times?
Good luck.
R
robby94gt
  • May 4, 2006
Thank you
MAF was dirty, iac was bad now car is running strong
Thanks
1994Vib.RedGT
585
Denver, CO
May 4, 2006
  • May 4, 2006
code 3 in electronics....
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
Please!? I need some help with my 1964.5 alternator conversion
  • Alabear94
  • Dec 6, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
GOvert
G
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
