hey guys,
I pulled this code.... "121 O,C,R Throttle Position sensor out of self-test range" today and was wondering if anyone else has pulled this in the past and what you did to fix it. My car has a pretty high idle at startup (1100 rpm). There are no vacuum leaks and I have a BBK 70mm TB with the idle screw barley touching the throttle arm. Also, I know that the tps is not adjustable on our cars, but is that only on a stock TB?
James
94 GT VERT AODE
Ported stock intake, 4.10's, shift kit, Granatelli MAF, BBK 70mm TB, 14*, BBK adj fpr, 2 chamber flows, BBK O/R H pipe, BBK underdrive pulleys, MSD 6A, Walbro 190 pump, k&n with silencer removed, sub-frame connectors, fan switch mod, 160* tstat , weight reduction
James
94 GT VERT AODE
