  • 1994 - 1995 Specific Tech
code 136, now what
  • Thread starter Thread starter Mustangless
  • Start date Start date Sep 23, 2005
Mustangless
903
home
Sep 23, 2005
  • Sep 23, 2005
Ran codes on my car again and I got 10, 111, 536, 136 and 632. THe only one that means and thing is 136.
136 Heated oxygen sensor indicates lean condition, left side.
Before I get all happy about maybe figuring out my problem I need to say. I did not warm the car before scanning, this doesn't matter does it?
Does this mean my o2 sensor is bad, or that I am running lean? If my o2 is bad, is the left the passanger side? I replaced the drivers side about 3k miles ago, never replaced passangers. If my car is lean, how do I fix that?
symptoms, bad performance, and terriable gas mileage.
what has been done. New drivers side o2, cleaned maf, plugs, wires, cap, rotor, fuel filter, air filter, ran seafoam and timing is on 12.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 23, 2005
  • Sep 23, 2005
The only way to run codes is to get the car to operating temperature......so you need to reset the codes, drive it for 10 miles, then do the koeo and koer codes with the motor still warm. That is the only way to can sucessfully run codes.
Also, on that 136 code, your O2 sensor is telling you that that bank is running lean, and you need to figure out why. my guess is one of your spark plugs will be white as chalk, and you have a busted fuel injector or wiring to it.
Scott
Mustangless
903
home
Sep 23, 2005
  • Sep 23, 2005
Scott
When I changed my plugs about 2k miles ago they were white. How could I tell if I have a busted fuel injector, and how do I find go about look for bad wiring?
HISSIN50
34
129
Sep 23, 2005
  • Sep 23, 2005
A cylinder balance test indirectly can help. If you pass all clear, the cylinders are all contributing to the cause. If not, check out the cylinder that is not RPM dropping when tested. NOTE that a cylinder that pops a CBT code is misfiring, but it is not necessarily injector related.
Furthermore, a noid light can be used to check injector firing (checks the harness and power and ground to the injector, but not the injector itself). The injectors get 12 volts key-on constant and a ground pulse when it is time to fire (the ground is computer controlled).
Good luck.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 24, 2005
  • Sep 24, 2005
Yeah, the only way to condemn one specific injector is to swap injectors and test the new cylinder. And the only way to test the computer's output would be w/ an oscilloscope.
Scott
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
