Hello,
I recently installed a used 88 5.0 mass air and 5 speed into a 65 mustang. The motor has a BBK 76 mm mass air meter, 30lb injectors, E303 cam, 70 mm (i think, TB), SCT chip, frickin autozone A9L computer, MSD coil and cap with stock dist. I used a RJM harness with the install, new o2s, vss, new fuel system 255 lph pump.
I will start and run the car, it fires up and runs good but usually after it gets good and hot it just shuts off and usually only happens when sitting at a red light. It doesn't miss or stumble just shuts off but always fires right back up.
I took it back to the shop, cleared the codes and let it run for about 20 min. Once it gets warmed up (180 deg), every so often it shuts off or will stumble and not die but this happens intermittently and I get the 14, 29 & 66 code.
I checked the voltage at the mass air and its within range, I could see the pip being erratic once its hot if this was the only code but the vss error I don't get because the car is not even moving and the sensor and harness are new.
I noticed that when the motor is warm the four relays that power the harness get hot from the header heat. I shot them with a temp gun and got as high as 170 deg on the top. Could these codes be tied together through a main power issue due to relays tripping out. I jiggle the wires and sometimes can get the motor to die but not always.
Any help is much appreciated
