Code 18 Spout Connector
  • Thread starter Thread starter curtisboytejr
  • Start date Start date May 27, 2012
curtisboytejr
33
  • May 27, 2012
Hey guys i have a 93 Gt that has been running wierd lately. sometimes it would run great and then after a few minutes it would just quit. I have changed the TFI module and that did not change anything so i thought it might be the the sensor thing that the TFI module plugs in so i just decided to replace the complete Distributor assy and i went to time it i noticed that it runs perfect with the spout connector out. when you put it back in it will run fine for a while and then starts dieing random, you pull the spout out and i ride for hours and never dies. So i decided it could be the coil or the ignition switch i was grasping for something. I also thought it could be a short to the computer so i got my meter and ohmed out the pin to the spout and it was great. Im lost guys, need some help here. here is a list of things i have replaced.
Complete Dist Assy (TFI Module included X2)
Coil
Ignition Switch
Plug Wires
Dist Cap and Rotor
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 28, 2012
  • May 28, 2012
Code 18 - SPOUT out or wiring fault - look for short to ground in SPOUT wiring going
back to the computer. Possible bad TFI or defective 22 K resistor in the IDM wiring
This code can disable spark advance and reduce power and fuel economy.
Remove the passenger side kick panel and disconnect the computer connector.
There is a 10 MM bolt that holds it in place.
Disconnect the TFI module connector from the TFI and the measure the resistance between the yellow/lt green wire and ground.
You should see greater than 100 K (100000) ohms.
Check the resistance from Pin 4 on the computer connector (dark green/yellow) and the dark green/yellow wire on the TFI connector. You should see 20-24 K Ohms (20,000-24,0000 ohms). The resistor is located in the wiring harness about 6” from the connector. You will need solder and heat shrink to replace the resistor if it is bad.
Next measure the resistance between the yellow/lt green wire on the TFI module connector and
Pin 36 on the computer connector. With the SPOUT plug in place, you should see less than 2 ohms.
The following is a view from the computer side of the computer connector.
This diagram is the wire side of the computer connector.
b]Diagram courtesy of Tmoss & Stang&2birds[/b]
curtisboytejr
33
  • May 28, 2012
Thanks for the great info, i will let you know what i find.
Admin Dude
Jan 4, 1985
43,422
21,629
234
Box behind Walmart
May 29, 2012
  • May 29, 2012
This is a troubleshooting problem and not an ECM tuning problem.
Thread moved to 5oh Tech.
curtisboytejr
33
  • Jun 6, 2012
hello jrichker, i did all these test and they were in all of the ranges you specified. One other strange thing i seen last night was i went to pull the codes again and it died everytime i ran the test. then i decided to do it one more time with spout out and i was able to do the test thid time. i got a new code. this time it is 19.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 6, 2012
  • Jun 6, 2012
Code 19 - Engine off - No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis. This is a wiring problem that is from a bad ECC power relay, bad connection, bad fuse link, bad ignition switch or a bad computer. The ECC relay is located on top of the computer under the passenger side kick panel. Pull the connector off any fuel injector and measure the voltage on the red wire: if its 12 volts or better, the ECC relay is OK. If the ECC relay is OK, pull the kick panel off and measure the voltage at pins 37 & 57. If it is 12 volts or more, then the computer's diagnostic firmware has taken a dump and is defective.
Engine running - Erratic idle during test (reset throttle & retest) - Idle Set Procedures .
See http://www.stangnet.com/mustang-forums/698148-help-me-create-surging-idle-checklist.html#post6855020 for the best way to set the mechanical base idle and cleaning procedure for the IAC/IAB.
curtisboytejr
33
  • Jun 6, 2012
Thanks again for the info. I will try this next and if it all checks out i guess its computer time
curtisboytejr
33
  • Jun 7, 2012
jrichker, i tested the voltage on the fuel injectors and voltage was above 12v. I checked pin 37 and it was at 11.9v and 57 was 12v
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 7, 2012
  • Jun 7, 2012
Go back and read the code 19 test path. The answer is in there...
curtisboytejr
33
#10
  • Jun 7, 2012
  • #10
is this what your talking about? Again thank you for all the help
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 10, 2012
#11
  • Jun 10, 2012
  • #11
You got it right...
radmacks
Winnipeg Manitoba Canada
Jun 6, 2020
#12
  • Jun 6, 2020
  • #12
I'm having the exact same issues, did you ever solve the problem ??
General karthief
Mod Dude
Aug 25, 2016
28,080
10,697
213
polk county florida
Jun 6, 2020
#13
  • Jun 6, 2020
  • #13
I hope he did, after all it was 8 years ago.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
