Code 31& 85
For the evap, plugging the valve back in will do it. (That as eliminating the system is a bad choice is not what you asked about.) If you use your multimeter to find an equivalent electrical load to the valve, that should be enough to placate the computer.
The EGR valve is at least a two step sensor and valve system. The static resistor plug ins may tell the computer the EGR is plugged in but not working.
  • Useful
Reactions: General karthief
