Code 62 How to fix??
Well pulling codes isnt exactly brain surgery. I also got other codes that are 3 digits. BTW I used a ford code reader I did use the grounding data link method.
I got code 62 and 82 which are not on that list but are in my book. The list of eec-iv codes are from 11-675. What am i missing guys?
Not sure .... but you should have ONLY 3 digit codes.
The only 2 digit codes we worry about is the airbag crap .... and that's a whole new testing method.
Try to pull them again & see if you get the same thing. Are you using a digital reader? The standard "blink & beep" readers are easy to get confused with.
Ya I am using a digital code reader.
KOER-176,62,411,82,332
I did notice the 2 digit codes are not in my chiltons or Haynes.
BTW, there is no R definition for 82, which is also suspect.
I will pull them again and see what happens.
Oh my. Maybe you have a 1993.5 model (where they were inbetween two and 3 digit codes). :D
I'm down with your thinking - let it pull them again.
Good luck.
Thanks Justin. I was indeed joking. Normally I wouldn't, but someone simply cant see two (Fox) and three (94-95 GT) codes from the same computer.
Chances are that the 'puter is correct if it ran well for a couple years. And it'd be a direct replacement or you'd remember spending some time rewiring a retrofit.
It's just very strange that your code reader would appear to be dropping the first number on every other code. I'd pull codes with a test light or by watching the CEL flashes if you need to confirm the readings.
Good luck and apologies for any confusion.
