My car started missing the other day at random, mostly in the low rpm's. My CEL flashed on and off about 4 times on my way home from work and was missing badly. This morning I checked for codes with the DSP thinking that I probably had a plug misfiring but it didnt read that, as this has happened before.
I pulled a P1000 code which is OBD-II Monitor Testing Incomplete and that is the only thing that i came up with. What does this code mean? What should I check next?
I've been having an intermittent code for the Cam Sensor (not regular enough to test the sensor) and every time I clear that code I get the P1000. Any other time it doesn't exist...
