hey all. i hope someone can help me out here.
i have an 01 gt and i have installed a bassani x and i keep pulling code p0133. Slow response from upstream o2 sensor drivers side. I do not think it is the sensor itself, because i have switched it and still had the same problem. I am pretty sure it is a problem sealing where the midpipe connects to the header. Would that make sense? Before this morning when i swapped a new gasket on the passenger side, i was pulling a p0153, same as now but with the passenger side. The only thing i could think of is that maybe the flange is not lined up quite right so maybe it is offset a little or something. so do you guys have any ideas on this? or a good way to fix it?
