Codes Read: PO135 and PO136 ring up (02 sensor related)...questions inside?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Got the codes read for why the service engine light is on...
It reads:
PO135
02 Sensor Heater
Bank 1, Sensor 1
PO136
02 Sensor
Bank 1, Sensor 2
Bank 1 is driver side right?
So does this mean I need to replace both sensors, front and back of the driver side?
both of those codes are circuit faults for bank 1 ( passenger side)
p0135 is a 02 heater cicuit fault and p0136 is a circuit fault for the downstream sensor on bank 1
I would first inspect the sensors for damage and then the harness itself. Look for a pinch in the harness, most likely without looking at the diagram I would bet any harness damage would have to be near the firewall on the passenger side.
Any places for the cheapest priced 02's?
I have a miss around the 2-2,400 rpm area under part throttle. I figure it is related to the 02's being out.
All the connections looked fine...
Don't you think it's slightly odd that both passenger side 02 heater circuits are out at the same time. I find it highly unlikely that two sensors went out at the exact same time.
Before you buy new sensors I would check the wiring to the sensors.
Did you just recently swap out your midpipe? Mine did the same type of thing after I changed mine out. It turned out to be a bad exhaust leak on the drivers side header-midpipe flange.
If this isn't the case, then you could switch your two rear sensors just to see if you still get the same code:shrug:
Actually the car had been hit in the rear before I bought it. It has the stock H pipe...and it pops, sometimes pretty badly under WOT.
It has no mufflers on it (I assume because the stock catback was damaged, so to save money they didn't add it back on).
Thanks for the reply
It's possible that these codes are related, and it's possible that they are unrelated. The reason being is that the downstream(after cat) sensors are monitored for maximum and minumum voltage output whereas the upstream sensors are not. Both codes can be a result of a damaged wire, moisture in the connector, open circuit, or a short to power.
The most common causes of the P0135 that I have dealt with is just a bad sensor(heater) or moisture in the sensor connector.
The most common cause of the P0136 that I have dealth with is either an exhaust leak or bad sensor. But make sure that the Bank 1(passenger side) downstream sensor wiring harness is not chaffed and touching something.
Clear all codes, then move the Bank 2 sensors over to Bank1 and vice versa, and see if the codes follow the sensors, or if the codes still show a circuit problem on that Bank 1
Check your battery as well. Low system voltage can also trigger these types of codes.
