Had a few questions now my car is ready to be started
First, My car is getting absolutly no spark. I took the coil plug and put it around the block no spark, tried poking a screw driver in there and bridge and still no spark. Im thinking its the coil, but the 2 wires that go to that does that give it power or is that just strictly tach? Or does this sound like a computer/relay problem.
Second i have the phantom water temp/ oil psi gauge. I spliced the 2 for the ground and power from the fuse is that ok? I was asking since when i unhooked the dist since the motor just now ready to fire up and make sure it was building oil psi. But when i turn ignition on it goes to 0 and when i try to crank it , it looks like its going under 0 like it doesn't have enough power to show the psi while cranking(is that normal).
thanks
thanks
