Coil over conversion
  • Thread starter Thread starter Black1987Stang
  • Start date Start date Sep 27, 2008
Black1987Stang
1,422
Jersey Shore
Sep 27, 2008
  • Sep 27, 2008
How's this look to everyone? I need to drop my front a little bit, my rear is perfect with my size tires, most normal spring packages only come with front and back.....and I think coilovers are a pretty good idea to have anyway..you can adjust em and whatever....plus when I had to change one of my front control arms it was a BITCH to get the spring back in there....Anything wrong with this method?
http://www.mustangdepot.com/OnLineCatalog2/Suspension/coil-springs.htm
Dino Dino Bambino
1,673
90
79
Cyprus
Sep 27, 2008
  • Sep 27, 2008
A coil over front suspension is definitely a good idea because there are many benefits:
1. Improved handling due to reduction in camber change during cornering.
2. Less risk of bump steer when the suspension is lowered.
3. Weight saving from the lighter springs. Even greater weight saving if you also add tubular control arms.
5. Adjustability, which is even better when you also add adjustable caster/camber plates.
Black1987Stang
1,422
Jersey Shore
Sep 27, 2008
  • Sep 27, 2008
Thanks for the reply, I plan on getting this kit or at least a similar one, what lb and inch spring should I go with?
It will be stock k member, control arms, lakewood or similiar struts with a 351w and skinnies up front if it matters.
Dino Dino Bambino
1,673
90
79
Cyprus
Sep 28, 2008
  • Sep 28, 2008
Depends on the type of set-up you're looking for; street, open track, or strip.
Black1987Stang
1,422
Jersey Shore
Sep 28, 2008
  • Sep 28, 2008
It would be a daily driver with a few runs to the track in the summer.
1nastynotch93
Cleveland, Ohio
Sep 30, 2008
  • Sep 30, 2008
My car is around 3,000 lbs. I am running QA1 coil over struts with QA1 springs. The car is mostly a street car with some track use. I talked to maximum motorsports and they recomended a 250lb spring and at least 12" tall so you do not have any coil bind. Once you go to coil over you will never go back.
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
