  • SN95 4.6L Mustang Tech
coil over ??
  • Thread starter Thread starter blkstangman88
  • Start date Start date Feb 18, 2006
blkstangman88
646
  • Feb 18, 2006
basicly i know nothing about it, all i know is i hear its better. how exactly do coil overs work and who sells quality kits?
D
d90212
253
kailua, hawaii
Feb 18, 2006
  • Feb 18, 2006
quality kit. = maximum motorsport.
they will help you pick a spring rate with what you are trying to accomplish with your vehicle.
this pic is on my modularfox.
wms004
2,864
Los Angeles
Feb 19, 2006
  • Feb 19, 2006
Maximum Motorsports front Bilstein C/O w/ 350lbs. springs.
WAde
hognutz
1,940
albany, oregon
Feb 19, 2006
  • Feb 19, 2006
basically you suspention now has the spring captured between the k-member and the control arm. a coilover moved the spring onto the strut which gives it a better mechanical advantage. then say a 800lb captured spring has roughly a 200lb wheel rate. so a coilover allows you to run a softer spring to attain the same wheel rate. Same wheel rate better ride. If you went up to a 1k plus spring you proably would not be able to compress it. so the coilover alows you to run more agressive rates if you so desire.
the downside is cost obviouly the nice kits like MM are buy no means cheap. you also have to run 4 bolt camber and caster plates with spherical bearings. so you get the picture it is not a poor mans mod.
I have not done them yet. I would like to try them as my car handles great but the ride is a tad on the harsh side on bad pavement. I ponder switching but I want my 9psi kenne bell and t-56 first.
san~man
O-G
A little grass shack on a big lava rock
Feb 19, 2006
  • Feb 19, 2006
I've had both. My dealer was nice enough to swap out the C/O for the same setup you have plus a PHB (and still give me a refund) after my C/O kit had some problems. The difference in ride quality was not enough IMO to pay that much more. Plus, the ride now with the PHB is far superior to just the C/O kit without one. Just my 2 cents.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 19, 2006
  • Feb 19, 2006
The coil over kit will cost $4k and make your car worth $4k less so think of them as actually costing $8k
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Feb 19, 2006
  • Feb 19, 2006
Only you would twist things that way.
I don't know advantage of Coilover set up, but I once saw 03 Cobra with tubuler K menber and A-arm with coil over set up at the show, and they look like they are off of much more expensive car
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 19, 2006
  • Feb 19, 2006
One has to be true to one's nature...
mity2
Jul 24, 2003
2,872
StateCollege PA
Feb 19, 2006
  • Feb 19, 2006
this is true
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Feb 19, 2006
#10
  • Feb 19, 2006
  • #10
what coilover kit are you looking at costing 4k????? i got mine from MM with C/C plates for 1500.
as for resale value, i dont plan on selling my stang for a long long time. the car is paid off.
coil pack bracket
  • SteveG94GT
  • Apr 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 11, 2026
SteveG94GT
D
How to test for a bad coil pack - 4.6 liter motor
  • DesertStang
  • Oct 7, 2025
2K
1996 - 2004 SN95 Mustang -General/Talk- Jan 14, 2026
DesertStang
D
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
