coil springs
For the rear you do not need anything. Just unbolt everything while supporting it with a jack then let it all down slowly. Re-installation is the reverse. For the front to get the spring out just put the car on jackstands and support the a-arm with a jack. Remove the tire, unbolt the brakes, struts and sway bar. be careful and let the jack down slowly till everything is fully released. You may have to pop the spring out. To put the spring in takes a different kind of compressor than we could find anywhere. We made our own with some threaded stock, a few big nuts, a couple of peices of steel and a welder.
