  • SN95 4.6L Mustang Tech
Cold clutch chatter
  • Thread starter Thread starter 67HotRod
  • Start date Start date Jun 23, 2005
67HotRod
27
SW MO
Jun 23, 2005
  • Jun 23, 2005
02 GT, 23,000 miles. This stupid thing has had a BAD clutch chatter in the mornings off and on for about a year. If you drive a lot, > 60 miles, then it won't do it the next day, other wise it will do it the first 5 or 10 miles of the day. This morning it about threw my hand off the dang shifter as I was moderately on it to get into traffic.
Had the Ford guy look at it when getting the 3650 TSB a few months ago, he said the clutch looked perfect. It didn't chatter with his test drive, as it is a long drive to get it to that dealer.
I thought it might be a small oil leak that shows up after it sits overnight, but why doesn't it do it when you put a lot of miles on it the previous day.
Ideas, anybody, please!!!!!
Mr GT 02
548
Peabody, MA
Jun 23, 2005
  • Jun 23, 2005
Its the stock clutch??
67HotRod
27
SW MO
Jun 23, 2005
  • Jun 23, 2005
Oops, yeah, it's stock.
Ghostface
226
Jun 23, 2005
  • Jun 23, 2005
I think I might have this also, can you describe what it sounds like?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jun 23, 2005
  • Jun 23, 2005
That's odd.
I have the same milage on my '03 and only get clutch chatter if i drive around a lot on a really hot day. Even then i really have to bog the motor down to get chatter.
67HotRod
27
SW MO
Jun 24, 2005
  • Jun 24, 2005
Well it's not so much a sound as it is a feel. It feels like it's gonna shake the dash off when you let out the clutch to get moving. You can feel it in the clutch pedal and the shifter. This is a VERY bad case. Sometimes you can get a little chatter and not be anything wrong. This is BAD. The shifter moves left and right about an inch when taking off.
You can minimize it by barely slipping it then dumping it at close to an idle, but that's a little tricky as the RPM's go down to about 300 before it gets enough momentum to get rolling, it's not too hard to kill it when you're doing that.
At light throttle leaving it's just plain annoying. At anything past part throttle leaving and it's tearing the heck out of everything. I've tried everything, slipping it more, less, side stepping the clutch with it out of gear, slipping it to try to clean off the surfaces, nothing works.
It won't do it at all after about 10 miles or after a lot of miles the previous day. The Ford guy tried easing out on the clutch and taking off in 2nd and 3rd at idle, that should make it chatter if it was going too.
I don't know, I'm starting to get a little hacked off at it.
67HotRod
27
SW MO
Jun 24, 2005
  • Jun 24, 2005
Mustang5L5 said:
That's odd.
That's what doesn't make sense, even on really hot days, after about 10 or 15 miles it's good, and doesn't get any worse no matter how long or hard you drive it. Also, it's not near as bad if it bogs, kinda backwards to what I know as clutch chatter from other cars.
67HotRod
27
SW MO
Jun 24, 2005
  • Jun 24, 2005
Also, I'm really easy on this thing, most of the time anyway. The motor doesn't move like the mounts are bad on it, and he should have seen the tranny mounts when he had it apart.
Am I crazy? Dad looking to buy 69 as daily
  • stonerCPA
  • Oct 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Thursday at 8:14 PM
ctandc
C
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
