combo question
  • Thread starter Thread starter stang9150
  • Start date Start date Apr 11, 2006
stang9150
142
Apr 11, 2006
  • Apr 11, 2006
fuel pump
what size pump for a 331
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 11, 2006
  • Apr 11, 2006
How much power do you intend to make? That is the deciding factor, not cubic inches.
All HP figures are Flywheel HP, no NO2 or forced induction.
325 HP - 24 lb injectors - 120 LPH
350 HP - 25 lb injectors - 130 LPH
375 HP - 27 lb injectors - 140 LPH
400 HP - 30 lb injectors - 150 LPH
Increasing the pressure increases the flow rate for the injectors. A 24 LB injector can flow 27 LBs if you turn the fuel pressure up from 40 PSI to 52.5 PSI.
Using a bigger pump than is required is OK, since the regulator returns the excess fuel to the tank. If you increase the pressure past 45 PSI, go to the next larger pump size, since flow rate decreases with pressure increase.
wild86stang
115
Milan, OH
Apr 11, 2006
  • Apr 11, 2006
I agree with jrichker, a larger pump won't hurt anything. Since the price difference isn't much between the different sized fuel pumps, I will soon be getting the 255lph pump. It's not much more and if you make future mods, you will already have the pump to support it.
vristang
4,933
101
124
Seattle
Apr 11, 2006
  • Apr 11, 2006
Another quality post by JR.
The cost of the pump is relatively small compared to the effort required to replace the pump.
jason
troyGT03
278
too close to memphis,tn
Apr 11, 2006
  • Apr 11, 2006
go with the biggest. about the same price as any of them. doesnt hurt.
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
  • Mindseye007
  • Aug 16, 2026
Mindseye007
D
1989 mustang 5.0 crank no start
  • Darkstang302
  • Nov 10, 2026
Fox 5.0 Mustang Tech Sunday at 8:36 PM
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
