Pokageek said:
Xactly. FORGET don't fear the gear in your scenario and go with don't overdo the gear. Mine is not a DD and 3.90's are almost (almost) too much for my type of driving (not track). You (almost) run out of steam with mine. PLUS as one fella mentioned and this is true, you lower your 0-60 with 4.10's or higher because of the SHIFT to 3rd b4 60. So what street driver wants that and I quarter mile once every 2 years! I agree with him. Oh yea, all yall that are dyed in the wool gear lovers..go ahead and
all you want.
I see no need to flame you or anyone else who has had 410's simply because you or they certainly can speak from experience
however
As always, there can be things that make steep gears not the same for everybody.
Three na combo examples to consider
1 Stock stick stang - stock power band
2 Typical gt40 combo - higher power band ... but not much
3 Mikes purpose built combo - power band shifted up a good bit
Steep ratios are not gonna be the same in each example
Cruising down the freeway at say 65mph ... Yes they will all turn about the same rpm assuming each has the same trans & tire size
however
That is not what will be so different ... its about how steeper gears compliment the higher power band.
The higher the power band has been raised ... the higher numerical value of gear one should be using.
Hearing a guy that has a little stocker Stang or even one mildly modded say
"410's are too much" would be very misleading for someone who had a purpose built combo that had a 6k plus effective power band.
Like all things ... one has to consider things like
is the car a dd
tire size
does the car see 1/8 or 1/4 mile use
etc
then again ... if we are talking about a Stang with a purpose built motor that turns some decent rpm ... this kinda guy has hopefully thought about all that
Power adders make all this stuff a whole different story for sure
but
Just trying to point out ...... you have to be careful about how you take the info you see on these boards ......
What the guy says may be true, but it may be all wrong, for you
One more thing and I am done ............
Weight is also a thing that needs to be considered when talking about rear gear selection.
A rule of thumb is the ratio gets steeper as the weight increases.
Grady
