  • SN95 4.6L Mustang Tech
comp 270 issues
  • Thread starter Thread starter dustang5398
  • Start date Start date Aug 17, 2009
D
dustang5398
  • Aug 17, 2009
When i do my full pi swap in my 98 gt i am wanting to put comp 270's in while i have the heads out. I've read on here that it is a good idea to degree the cams. I've got no experience doing this. So my question is it possible to degree them w/o the the heads actually on the motor? B/c i was planning on having a shop do this. I can handle everything else.....
J
jomull55
202
lucas, OH
Aug 17, 2009
  • Aug 17, 2009
degreeing has to be done with the heads and cams on the motor.
Tim2002GT
635
Tulsa, Oklahoma
Aug 17, 2009
  • Aug 17, 2009
I may be wrong, but you may have a problem with PTV contact with those cams on a NPI shortblock.
D
dustang5398
  • Aug 17, 2009
yes, i am aware of the ptv clearance w/ these cams. I really want to use them but i may have to notch out the piston tops for valve clearance.....
lvmustanggt
721
Las Vegas
Aug 18, 2009
  • Aug 18, 2009
I have this cams , shop did the install and no ptv problem.
D
dustang5398
  • Aug 18, 2009
You also have the full pi motor.
Tim2002GT
635
Tulsa, Oklahoma
Aug 18, 2009
  • Aug 18, 2009
Good deal, just wanted you to be aware of what you were getting into! Those cams do sound great though!
sick2v
66
S.A. Tx
Aug 18, 2009
  • Aug 18, 2009
You need to degree heads with cams installed. As for valve clearance, I recommended a new set of springs. The comp 270 are lifted at .550 for both exhaust and intake valves. That's pushing it on a set of stock P.I. Heads. Especially if their used already, then wear and tear might be a heavier factor. You can get a set of comp beehive springs with .600 lift and you wont have to notch anything. Either way you can still run the cams on a set of P.I. heads.
D
dustang5398
  • Aug 19, 2009
I've never heard of this before. I've heard of flycutting the pistons and modifying the bottem of the valves to clear ptv but not by putting in .600 lift springs.
J
jomull55
202
lucas, OH
Aug 20, 2009
#10
  • Aug 20, 2009
  • #10
He just means you need a stiffer spring so there's less chance your valves will float down and meet the piston. the stock springs aren't made for a cam that has .550+ lift
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
