comp 270 issues
dustang5398
When i do my full pi swap in my 98 gt i am wanting to put comp 270's in while i have the heads out. I've read on here that it is a good idea to degree the cams. I've got no experience doing this. So my question is it possible to degree them w/o the the heads actually on the motor? B/c i was planning on having a shop do this. I can handle everything else.....
You need to degree heads with cams installed. As for valve clearance, I recommended a new set of springs. The comp 270 are lifted at .550 for both exhaust and intake valves. That's pushing it on a set of stock P.I. Heads. Especially if their used already, then wear and tear might be a heavier factor. You can get a set of comp beehive springs with .600 lift and you wont have to notch anything. Either way you can still run the cams on a set of P.I. heads.
I've never heard of this before. I've heard of flycutting the pistons and modifying the bottem of the valves to clear ptv but not by putting in .600 lift springs.
