  • SN95 4.6L Mustang Tech
comp cams installed question.
  • Thread starter Thread starter gottabfordtough
  • Start date Start date Jul 7, 2004
G
gottabfordtough
38
indiana
Jul 7, 2004
  • Jul 7, 2004
i just finished installing my comp cams. 102500. the car runs great, no stalling problems, didn't notice any huge difference but does seem to rev faster. question is the cams are really loud though. they quite down at about 1000 rpm but at idle they seem to chatter. almost sounds like my car is knocking but i know it isn't. iv heard other people say the compcams are loud. is this normal??
Ryan02Stang
1,181
Arlington Heights, Illinois
Jul 7, 2004
  • Jul 7, 2004
Is it a sewing machine noise that is RPM dependent???
G
gottabfordtough
38
indiana
Jul 7, 2004
  • Jul 7, 2004
yes. that's it like a sewing machine. a kinda loud one. once it hits 1k rpm gone and really smoothe. but at idle does sound like a sewing machine. normal???????
nickthegenius
1,631
Elwood, IN
Jul 7, 2004
  • Jul 7, 2004
It depends on your definition of loud. If you've ever noticed the clicking noise that your injectors make, my cams sound like an extra set of injectors. Just a muffled tick here and there.
If yours are much louder, you may want to be concerned. Did you measure the base circles of the cams before you installed them? Mine were all within spec and still make a little noise. Comp had a problem earlier in the year with a bad batch of cam blanks that had smaller base circles and caused many people headaches.
If you're not already on there, check out http://www.modulardepot.com and ask around there. It seems like 75% of the people there are cammed, whereas you're more like a 1%-er on Stangnet if you're cammed. You'll find many more informative answers on that board.
Ryan02Stang
1,181
Jul 7, 2004
  • Jul 7, 2004
There shouldn't be any valvetrain noise like that. Check out this thread I started on ModularDepot. It seems a LOT of people are having this problem and it tends to be the timing chain tensioner.
http://forums.modulardepot.com/showthread.php?s=&threadid=25357&highlight=valvetrain+noise
kboy262
437
Atlanta-Kennesaw
Jul 8, 2004
  • Jul 8, 2004
You might want to check on the base circles. I have Comps on my car and have zero noise issues. You might just be one of the unlucky people that got a bad set.
G
gottabfordtough
38
indiana
Jul 8, 2004
  • Jul 8, 2004
about the timing chain tinchener, what one should i go with and where to get. it. and i'll have to remove the front cover right??
nickthegenius
1,631
Elwood, IN
Jul 8, 2004
  • Jul 8, 2004
Yeah, you'll have to pull the front cover unfortunately.
BTW, where in Indiana are you? Just curious. Ever go to IRP?
G
gottabfordtough
38
indiana
Jul 8, 2004
  • Jul 8, 2004
almost every tuesday. and the last friday. what do you drive mabey i've seen ya? ive also heard of it being lifters. i guess they have lash adjusters. that may be the first try. ive got the only 04 orange stang out there (that ive seen) my best was last friday i ran a 13.64 my mods are in my sig. i just got the cams in yesterday im hoping for a 13.5 or better with the cams. what are you running and how fast??
nickthegenius
1,631
Elwood, IN
Jul 8, 2004
#10
  • Jul 8, 2004
  • #10
I'm barely in the 13's I've got some driver-related issues. I used to get the car to hook OK on the 18's last year. Now with the increased power from the cams, headers, plenum, etc. I haven't found a happy medium launching the car. It either bogs or annihilates the tires. I picked up some 15" V6 wheels for drag radials and I'm hoping that will solve the problem when I get the money for the tires.
I was down there at the last Midnight Madness, but I got parked after my 2nd run due to the lack of a helmet. My best was a 13.80@104 with a 2.3 60ft. I didn't realize you could use a helmet with a Snell M95 rating or I would have brought my motorcycle helmet
G
gottabfordtough
38
indiana
Jul 8, 2004
#11
  • Jul 8, 2004
  • #11
et streets will help for sure back when i didn't have my gears i was running 13.9's i put on slicks and ran a 13.54, almost half a sec. but i havnt ran the slick after the gears. the 13.6 was on street tires, im sure to be in low 13's with slicks. but i like to keep mine how i drove it there. so when people ask i dont' wana be the one to say well with slicks and timing at 15 and open exhaust it'll run this. my 13.6 is just they way i drive it everyday to work. are you the one i talked to about the cams a while back. are you going tuesday.
nickthegenius
1,631
Elwood, IN
Jul 8, 2004
#12
  • Jul 8, 2004
  • #12
Hopefully I will be there if the weather is good and I get off work in time.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
J
68 Mustang with Foxbody Engine Stalling Issues - MSPNP2
  • JayV68Stang
  • Mar 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 13, 2025
JayV68Stang
J
