Comp Cams
  • Thread starter Thread starter MsCammed01GT
  • Start date Start date Nov 21, 2014
  • 3
First Prev 2 of 3 Next Last
MsCammed01GT
32
GREER, SC
Dec 12, 2014
#21
  • Dec 12, 2014
  • #21
The only reason I would go with Pro Dyno is because they seem to specialize in Ford - there is a shop over by me but they seem to deal with Chevy mostly. The prices are pretty much the same too. My boyfriend mentioned that he had come to a halt, he said we will have to order the adjustable crank gears. Where would I find some for a good price and good quality?
MsCammed01GT
32
GREER, SC
Dec 12, 2014
#22
  • Dec 12, 2014
  • #22
sneaky98gt said:
Like I said, I wouldn't worry too much about the numbers. A couple clicks of the mouse can easily change the numbers by 6-8%. The real test is how it drives (idle quality, part throttle characteristics, fuel mileage, etc.) and how it runs at the track.
Yes, I'm currently in Raleigh. I've never been there, but I have several friends who have had their cars tuned by Dan at Pro Dyno. I haven't heard any complaints. The only thing I've noticed with him is that his numbers are STD corrected (vs. SAE), and STD reads about 4% higher than SAE. Not a big deal, but a little pet peave of mine when tuners use that to make it look like the car is making more power than it actually is.
This is the one we ordered actually! http://www.summitracing.com/parts/tfs-51800505/applications/
squeak93
2,304
384
164
Joplin, Missouri
Dec 12, 2014
#23
  • Dec 12, 2014
  • #23
sneaky98gt said:
Holy smokes, Squeak! Haven't seen you around these parts in ages! Good to see you around.
As to the OP, the cams absolutely need to be degreed in. I used to be of the opinion that it wasn't that important, but after I put my cams in and they were off by SIX degrees, I realized just how important it was. Mine were 6 degrees retarded, which wouldn't have hurt anything other than power, but if they happened to have been 6 degrees advanced and I installed them straight up (i.e. without degreeing), I'd likely be pulling everything back apart to fix the broken valves....
With enough time and patience, and the right tools, I think most anyone that is somewhat mechanically inclined can degree in cams. It's not a very technically challenging task, just one that takes some attention to detail. However, I'd echo Squeak's comments that it may not be the best idea for someone to try on their first time even having the valve covers off. I'd opt to pay someone else to do it in that case.
The TFS adjustable crank gears are by far the easiest and best way to degree the cams in. Don't use the adjustable cam gears.
I believe that a tune is required to get the most out of a set of cams. No major changes are needed for a mild cam, but there are some small things I'd adjust if it were my car. Idle quality, part throttle responsiveness, fuel mileage, and overall power output will suffer if the tune isn't tweaked a bit.
I've been lurking around off and on over the years. I keep busy and only try to post when I've got useful info that could help others.
Op, good luck and keep us updated of power gains and sotp feel once the cams are in.
FWIW, we put hitec stage 1 cams in a pi swapped 98 GT and it did not want to idle without a tune. Those are baby cams compared to what most guys are running.
Reactions: MsCammed01GT
MsCammed01GT
32
GREER, SC
Dec 16, 2014
#24
  • Dec 16, 2014
  • #24
Thank yall for all the input!
sneaky98gt
2,387
144
114
NC State University
Dec 16, 2014
#25
  • Dec 16, 2014
  • #25
I forgot to answer your question earlier about the adjustable cam gears. These are the ones you need: http://www.modularheadshop.com/TFS-51800515.aspx
Although they are more expensive than I remember them being.
MsCammed01GT
32
GREER, SC
Dec 17, 2014
#26
  • Dec 17, 2014
  • #26
Oh we bought those last week actually, just waiting for their arrival
Modular2v
3,222
23
99
oklahoma
Dec 31, 2014
#27
  • Dec 31, 2014
  • #27
MsCammed01GT said:
Well looks like I will be putting 275 on the tires instead of the 305 in the rear - but 290 is still good! Luckily I already bought my SCT tuner. You are from NC correct? Have you ever been to Pro Dyno?
Definitely wouldnt be worried about the dyno #s as much as the track times and drivability. Every dyno is different. My car has seen a 80hp variance between two different dynos. How did the install go?
MsCammed01GT
32
GREER, SC
Dec 31, 2014
#28
  • Dec 31, 2014
  • #28
Well i have the cams in now, but the previous owner didn't take very good care of the car and I have a bad fuel pump so I'm having that replaced also. I found the time slip from the previous owner and the car ran a 8.93 in 1/8th reaction time is .009
Modular2v
3,222
23
99
oklahoma
Jan 2, 2015
#29
  • Jan 2, 2015
  • #29
Keep in mind the reaction time in NO way reflects the ET. Reaction time really only matters in bracket racing or true heads up racing. What was the 60ft? Final Trap MPH?
MsCammed01GT
32
GREER, SC
Jan 13, 2015
#30
  • Jan 13, 2015
  • #30
Okay guys - new cams are in - had some kind of trouble with the air/fuel ratio but we got it fixed.
Modular2v
3,222
23
99
oklahoma
Jan 14, 2015
#31
  • Jan 14, 2015
  • #31
You get it tuned? Have the graph?
MsCammed01GT
32
GREER, SC
Jan 14, 2015
#32
  • Jan 14, 2015
  • #32
No I haven't had it tuned yet - I am taking it next month to Pro Dyno. I am trying to figure out how to post a video on here but I can't seem to find it. Any help lol?
Modular2v
3,222
23
99
oklahoma
Jan 14, 2015
#33
  • Jan 14, 2015
  • #33
I've always posted it to youtube and thrown up a link in here! When you get it on the dyno and tuned, they SHOULD be able to hammer out all your air/fuel issues
MsCammed01GT
32
GREER, SC
Jan 14, 2015
#34
  • Jan 14, 2015
  • #34
Okay here ya go!!! View: http://youtu.be/bpzwya2kqds
MsCammed01GT
32
GREER, SC
Jan 14, 2015
#35
  • Jan 14, 2015
  • #35
Sorry for the crappy quality!
Modular2v
3,222
23
99
oklahoma
Jan 14, 2015
#36
  • Jan 14, 2015
  • #36
ahhh! It says the video does not exist!
MsCammed01GT
32
GREER, SC
Jan 14, 2015
#37
  • Jan 14, 2015
  • #37
ahhh man well you can go check it out on my youtube or instagram --
Youtube: Victoria M
Instagram: blown04sb_cammed01gt
MsCammed01GT
32
GREER, SC
Jan 14, 2015
#38
  • Jan 14, 2015
  • #38
2001 Mustang GT: View: http://youtu.be/m8tmENXF8rk
MsCammed01GT
32
GREER, SC
Jan 14, 2015
#39
  • Jan 14, 2015
  • #39
Tahhhhdahhhhh
Modular2v
3,222
23
99
oklahoma
Jan 14, 2015
#40
  • Jan 14, 2015
  • #40
Sounds Good! Make sure to get some video on the dyno and post the graph!
  • 3
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 9:30 AM
Ryu
