comp wont thro codes
  • Thread starter Thread starter bcd
  • Start date Start date Jan 13, 2006
bcd
274
arab al
Jan 13, 2006
  • Jan 13, 2006
i used the instructions. sensors never even start clicking. any help
bcd
274
arab al
Jan 13, 2006
  • Jan 13, 2006
TTT
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 13, 2006
  • Jan 13, 2006
With the power off, measure the resistance between the computer
test ground (black/white wire) on the self test connector and battery
ground. You should see less than 1.5 ohms.
If that checks good, remove the passenger side kick panel and
disconnect the computer connector. There is a 10 MM bolt that holds
it in place. Measure the resistance between the STI computer self
test connector (red/white wire) and pin 48 on the computer main
connector.
See the following website for some help from Tmoss (diagram
designer) & Stang&2Birds (website host) for help on 88-95 wiring
http://www.veryuseful.com/mustang/tech/engine
The following is a view from the computer side of the computer connector.
bcd
274
arab al
Jan 13, 2006
  • Jan 13, 2006
thanks man i have been waiting for you to chime in.
Black1987Stang
1,422
Jersey Shore
Jan 13, 2006
  • Jan 13, 2006
Jrichker while I got ya, since my stang doesnt have a check engine light (87) what wire do i hook it up to looks like 17 on ur diagram? I saw an article on it somewhere and I cant find it. I think it calls for a bulb in the HELP section and to solder that wire to the circuit on the back of the cluster, and im assuming a ground too if there isnt one back there.
bcd
274
arab al
Jan 13, 2006
  • Jan 13, 2006
http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 13, 2006
  • Jan 13, 2006
Copied from mustang88GT:
I have not finished it yet but I put the bulb in and it works. There are wires that you can tap into and run to the self test connector. The reason I have not run the wires yet is because I am tripping 2 codes because I did not run wires for the secondary fuel pump or speed senor yet for the MAF conversion... but it should be real easy to do here is
Adding a "Check Engine" light
Another difference between the speed density and MAF cars is that MAF cars have a "Check Engine" light in the dash to alert you to possible serious problems and it makes reading out self test codes much easier. The MAF cars have the "Check Engine" light located in the light panel on the lower right of the instrument cluster. Speed density cars don't have this window, but there is a "Check Engine" position for a light in the tachometer face, though there is no bulb installed. The wire from the EEC to the bulb (via the flex connector) is also missing.
In the '88 harness (not sure of other years), there is a tan and a black/blue wire connecting up to the 'Check Engine' circuit on the instrument cluster flex circuit. For MAF models, the tan wire hooks to the EEC STO/MIL line and the black/blue is for the lamp test out when you start the car. I don't know what these are connected to in an '88, but the test out feature does not work, and the STO/MIL line at the EEC-IV and self test connector is yellow/black. The wires connected to the check engine lamp probably end at some open connector somewhere, but I couldn't track it down, so I cut the tan and black/blue wires off the flex connector and ran a new wire to the STO/MIL wire on the self test connector under the hood (you could also tap in by the EEC-IV, but it was easier for me to go through the firewall. You can get a bulb socket from the HELP! rack at the local parts store, put in a N194 bulb, and voila, you now have a working check engine light.
bcd
274
arab al
Jan 13, 2006
  • Jan 13, 2006
i couldn't find an 89 harness when i did my car so i got an 88 and changed it to mass air. do you think that has anything to do with it
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 13, 2006
  • Jan 13, 2006
The wiring for the computer self test connector is the same for both years. Unless you miswired something, it should not cause problems. See http://www.stangnet.com/tech/maf/massairconversion.html for instructions to check your wiring.
AZNEAL311
85
Phoenix
Sep 23, 2006
#10
  • Sep 23, 2006
  • #10
I have an 88 that was converted to MAF when I bought it. I have a check engine light near my tach. with a bulb in it. I see it light up when i am starting my car. However When I try to pull codes i get nothing. I have tried using the CE light,multimeter and test light and I havnt got any thing. Anyone have the same problem and have an idea on what I should do? I have yet to try a STAR reader waiting for my friend to find his for Ranger with a 302 he dropped in. Untill then any suggestions?
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Nov 16, 2026
Fox 5.0 Mustang Tech Tuesday at 7:31 PM
mikeah
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
Paristic draw?
  • Creomod
  • Nov 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
General karthief
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
