Completely eliminated exhaust drone
  • Thread starter Thread starter LX Dave
  • Start date Start date Apr 12, 2021
  • 3
First Prev 3 of 3
87cooper
31
11
18
Boise
Aug 19, 2023
#41
  • Aug 19, 2023
  • #41
I love the sound of my exhaust, but the drone will rattle my teeth. If I wasn't already planning on replacing my exhaust, I would go this route. Here is a great calculator for this mod.
Drone Calculator
Web Site Builder Description
super-null.com
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,140
2,760
224
Vass, NC
Aug 20, 2023
#42
  • Aug 20, 2023
  • #42
Yeah... Turbos do apparently help, but I guess when they get big enough, they don't muffle the sounds the same way. The incon setup was pretty quiet. Much smaller turbos, though.
Reactions: AeroCoupe
LX Dave
5 Year Member
Jul 2, 2017
240
182
53
Aug 26, 2023
#43
  • Aug 26, 2023
  • #43
Haven't been around a lot and just saw this thread come back up.
The pipes are a slip fit into the elbows I used, at least two inches in. The band clamp was used so I could easily get it apart if something needed to be changed. Still need to make some supports for the ends, even though there's no movement to them.
Everything I heard is these work in a very small frequency range, pipe length is pretty picky. This spring I decided to add a couple of inches to the pipes (found some new calculations for length). It got even better now. I believe I'm at 26 or 27 inches (can't remember exactly).
If anybody is making these, just remember, drive the car until everything is up to temp. The temperature will change results a little.
If you are tuning for say 1900 rpms and use a 28.5" tube, it will help the drone at rpms just above and below that, but tune for the rpm where the drone is at its max.
I did download a spectrum analyzer, but not sure how good it was. Took readings before and after (both when everything was at operating temps). At first, I was unimpressed with the after readings. The analyzer showed only a small change, but by ear, it was huge.
Here's the new data I got and it seems pretty accurate:
Drone RPM--1/4 wave tube length
1700--32"
1800--30"
1900--28.5"
2000--27"
2100--25.75"
2200--24.5"
2300--23.5"
2400--22.5"
2500--21.5"
Since there are usually elbows involved, I just used a tape measure and checked the length going down the center of the tube.
Reactions: General karthief
  • 3
First Prev 3 of 3
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
G
Quiet my 2015 GT on the cheap
  • gsrblack
  • Feb 12, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Apr 16, 2025
gkomo
