  • SN95 4.6L Mustang Tech
compression and a few other questions
  • Thread starter Thread starter 97gtconv.
  • Start date Start date Apr 17, 2007
97gtconv.
244
Lock Haven, PA
Apr 17, 2007
  • Apr 17, 2007
a friend of mine might be giving me his stock rods and pistons out of his 03 cobra. which is great but i have some questions. what cc is the 03-04 pistons? what compression would i be with P.I. 2valve heads? is my cam choices changed since there might be less clearence between the valve and the piston? would it be wise to go with the cometic head gaskets to reduce compression? if so what cams would you recommend? thanks alot, jason
Superhereaux
chicks make me feel inadequate
538
South Texas
Apr 17, 2007
  • Apr 17, 2007
you can get any cams you want actually, you'll have all the room in the world with those pistons
hint: they're dished, they lower compression
97gtconv.
244
Lock Haven, PA
Apr 17, 2007
  • Apr 17, 2007
dumb me. had brain fart. so around 9:1-1 compression or so?
Superhereaux
538
South Texas
Apr 17, 2007
  • Apr 17, 2007
couldn't tell you although i'm sure it'd be much lower than that
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 17, 2007
  • Apr 17, 2007
dont use those pistons. they are the weak point of the terminator.
97gtconv.
244
Lock Haven, PA
Apr 17, 2007
  • Apr 17, 2007
that kinda sucks. really would've like to use the pistons but i guess i'll have to rethink my options cause i wanna stay n/a with dope. future would be built motor and turbo but i'm a college kid so i'm naturally poor
Superhereaux
538
South Texas
Apr 18, 2007
  • Apr 18, 2007
really?
you'd think with a couple of 700hp 'o3-o4 cobras running around they'd be plenty tough
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 18, 2007
  • Apr 18, 2007
they are the first part to crack usually. the ringlands tend to crack from what ive seen. ford was supposed to use Manley pistons, but ended up using a less expensive company.
01Steeda
732
Baton Rouge, LA
Apr 18, 2007
  • Apr 18, 2007
he is right. I wouldnt waste my time on that swap. just get manley from the get go.
D
Dragstr05
643
Stafford VA
Apr 18, 2007
#10
  • Apr 18, 2007
  • #10
Superhereaux said:
really?
Thats what I was thinking. Is the "cracking" relative to power output, or are they just cracking by defect?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 18, 2007
#11
  • Apr 18, 2007
  • #11
Cobra pistons do suck in the 4V they are aluminum and only have .001 PTW clearance and they seize to the cylinder walls under high speed pulls when they expand from heat.
Do not put used parts on you car especially suspension and drivetrain components.
97gtconv.
244
Lock Haven, PA
Apr 18, 2007
#12
  • Apr 18, 2007
  • #12
thanks, not even the rods cause the rods measured good.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 18, 2007
#13
  • Apr 18, 2007
  • #13
The rods would be a major step up from GT rods. The 2V rods are very weak.
97gtconv.
244
Lock Haven, PA
Apr 19, 2007
#14
  • Apr 19, 2007
  • #14
ok so would my stock pistons and SHM ring kit do you think it would safely take a 125 tuned wet kit consistenly?
jstreet0204
939
Winston Salem, NC
Apr 19, 2007
#15
  • Apr 19, 2007
  • #15
There is nothing wrong with using those pistons and rods, as long as you have them magna fluxed and checked over. They are going to be stronger than your gt pistons and rods. They do have pretty tight clearances on a stock cobra which causes some problems in extreme conditions, but as anybody that has any actual engine building experience knows, that can be taken care of in the final hone. Now they are dished so your compression ratio is going to go down, where as in a nitrous motor you want more compression, so that is going to be a negative factor. Bottom line, is if you are getting them for a good price and they check out ok, and you can live with the lower comp ratio, they should be fine.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Motor given to me and I’d like to rebuild it what do I need to do
  • Creomod
  • Dec 14, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 16, 2024
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
