Compression check question
  • Thread starter Thread starter BlooDReigN
  • Start date Start date Aug 15, 2004
BlooDReigN
283
Calgary, Alberta
Aug 15, 2004
  • Aug 15, 2004
I am about to do a compression check here, but I misplaced my Haynes manual. What are the factory compression numbers for the 302 HO?
Thanks in advance
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 16, 2004
  • Aug 16, 2004
With the engine warmed up, remove all spark plugs and prop the throttle wide open, crank the engine until it the gage reading stops increasing.
On a cold engine, it will be hard to tell what's good & what's not.
Some of the recent posts have numbers ranging from 140-185 psi. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn.
There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
C
Engine Cylinder 5,,7, & 8 run significantly cooler than the other cylinders
  • Crisfixes
  • Sep 27, 2025
Fox 5.0 Mustang Tech Sep 27, 2025
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
