  • SN95 4.6L Mustang Tech
compression equals power, sooo
  • Thread starter Thread starter tontot77
  • Start date Start date Dec 19, 2003
tontot77
Do I look like a :taco: in this picture?
Apr 2, 2003
409
Dyer Indiana
Dec 19, 2003
  • Dec 19, 2003
so my engine is a 4.6 4v with a GT40 turbo at 8 psi... I used to be making 470 hp and 490 lbs of tq... but that was at stock compression. I had Tim lower the compression to right around 9.0:1 so do any of you engine Guru's that lurk around stangnet have any guess as to how much power I will lose with a lower compression at the same psi?
White360RFnSwee
869
West Palm Beach FL
Dec 19, 2003
  • Dec 19, 2003
what is stock cobra compression?
That means you can turn the boost up..
Aaron 4.6
2,695
Georgia
Dec 19, 2003
  • Dec 19, 2003
I expect you might lose 15-20 hp. Compression makes power, but low compression and high boost makes a lot more power than low boost and high compression...
Route666
1,652
Brisbane, Australia
Dec 19, 2003
  • Dec 19, 2003
with the same boost I would estimate
new power = (original comp ratio / new comp ratio) * old power.
Route666
1,652
Brisbane, Australia
Dec 19, 2003
  • Dec 19, 2003
make that new / old lol DOH!
98superstangGT
1,239
sc
Dec 19, 2003
  • Dec 19, 2003
there is no way that can be right????? Thats saying its dropping hime down to around 430 or so hp. Isnt the cobra's compression like 9.8:1?? If it is and your dropping down to 9.0 then you might lose about 15 or so at most. Not 40 or so hp like that equation was giving you.
mogs01gt
3,113
30
119
Ohio
Dec 19, 2003
  • Dec 19, 2003
same timing? or is that the trick question part you are going for .
tontot77
Apr 2, 2003
409
Dyer Indiana
Dec 19, 2003
  • Dec 19, 2003
I do plan on turning the boost back up so that I run back around 500 hp, but... not until I can get a new dyno tune and chip burned... I'll post more after I get home tonight... like the current a/f ratios
mogs01gt
3,113
30
119
Ohio
Dec 19, 2003
  • Dec 19, 2003
what about timing
Aaron 4.6
2,695
Georgia
Dec 19, 2003
#10
  • Dec 19, 2003
  • #10
I'm not saying this to be insulting, but that is a blatant guess and wrong to boot. There are some pretty fundamental physical laws that can be expressed as ratios, but this is a much more complicated system than that. Desktop Dyno would not be a very powerful tool if we could use systems like the one above and a simple calculator.
Route666
1,652
Brisbane, Australia
Dec 19, 2003
#11
  • Dec 19, 2003
  • #11
Yeh, it works for na more, with a turbo the cylinder would fill easier, so you would get a little more in, so it wouldn't drop quite so much, I agree. It was just a roughstimate.
tontot77
Apr 2, 2003
409
Dyer Indiana
Dec 19, 2003
#12
  • Dec 19, 2003
  • #12
same timing, and whats the compression ratio in the new 03 cobra's?
T
twidge
1,364
#13
  • Dec 19, 2003
  • #13
I vote you lose 8 RWHP all across the board @ same timing, same boost, etc.
tontot77
Apr 2, 2003
409
Dyer Indiana
Dec 19, 2003
#14
  • Dec 19, 2003
  • #14
8? wow, thats an optimistic guess, I hope your right on the money... Whats the stock 03 cobra run as far as psi? I'm trying to figure out how much boost I can run in the future...
V
pushrod 5.0 (MILD/ Torque) turbo build for an old scout II help
  • vz58
  • Apr 21, 2024
  • Other Auto Tech
2K
Other Auto Tech Jan 21, 2026
Flyboy60
F
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
Engine removed timming chain put back a new one now i lost power?
  • Creomod
  • Oct 5, 2021
3K
Fox 5.0 Mustang Tech Oct 15, 2021
Mstng93SSP
Compression low on one cylinder
  • PDHSB
  • Sep 23, 2020
1996 - 2004 SN95 Mustang -General/Talk- Sep 25, 2020
Michael sommers
Best block / parts for Turbo build
  • jeannelle101
  • Aug 31, 2020
3K
1996 - 2004 SN95 Mustang -General/Talk- Jan 7, 2021
Mustang5L5
