  • SN95 4.6L Mustang Tech
Compression?...Nope
  • Thread starter Thread starter FordTard
  • Start date Start date Nov 20, 2008
First Prev 2 of 2
fast97gt
1,082
north carolina
Nov 23, 2008
#21
  • Nov 23, 2008
  • #21
BurningRubber said:
Easiest way is to unplug all of the fuel injectors from their harness. That way you have no fuel being wasted in any cylinder. Spark won't make a difference in the other cylinders you aren't guaging the compression on, so you only need to remove the coil on the cylinder you are working on when you get to it...
thinks for the added tip, sorry i didnt think of it
F
FordTard
17
Orlando
Nov 23, 2008
#22
  • Nov 23, 2008
  • #22
The way I did the test was as fallows:
I first pulled all the plugs to allow the engine to spin more freely and I unplugged the injectors so none of the cylinders would flood. I then screwed compression gauge on to each cylinder and allowed the engine to turn over a good 5 to 6 times to read max pressure in each cylinder. I went all the way around the banks again to get a second reading. I then added a small amount of oil to the cylinders that seemed low to check if it was a valve or the rings (the extra oil will temporarily seal the rings).
I recorded everything I did as I went and my friend who was helping me watched the compression gauge as well to double check my numbers.
I think I was very thorough in the way I performed the test. I think I will have time tomorrow to give it a try again and see if the numbers are any better.
What temp should the engine be when I do this again. Last time it was warm but not hot because I was unable to pull the plugs when it was fist shut down. And does the outside ambient air temp matter?
thanks again
BurningRubber
1,865
24
58
Nov 23, 2008
#23
  • Nov 23, 2008
  • #23
No problem...
Also, keep the throttle wide open during the test.
I checked mine with the motor dead cold because I am weary about messing with the plugs on a warmed up 4.6.
First Prev 2 of 2
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • Gulftown980x
  • Jul 29, 2026
squeak93
