Compression Problem
  • Thread starter Thread starter Faolan
  • Start date Start date Jun 18, 2006
F
Faolan
  • Jun 18, 2006
I just rebuilt my 347 (due to ignorance of not knowing to seal lower head bolts )
And of course I suffer from the uncontrollable need to upgrade my motor , so I took the opportunity while it was apart to get the AFR185s machined ( a fresh deck surface, cut pockets for upgraded springs (due to the new cam), lapped the valves, honed the valve guides), up’d the cam (previous cam was too smooth), new long tube headers, and decided to go with Cometic head gaskets.
After the build, I apparently didn’t have the timing correct and had a few very rough (Very Rough) starts before getting it running. After that, it idled nicely (with very sweet snappy revs), but would cut out around 3000rpm (figured the timing was still off, oh and no timing light only by ear).
The exhaust smelled pretty rich, so I pulled the plugs, and 7 out of 8 were oily and smelled of gas, #5 was brownish in color and didn’t smell of gas.
I did a quick comp check of all the cylinders, all were around 10:1, except #5, the gauge didn’t even twitch.
First I tried re-adjusting the valves on that cylinder (thinking they may not have been closing all the way), still no reading. Blew air into the cylinder to see if I was getting blow by, didn’t feel anything through the breather, carb or exhaust.
Dropped the oil, it looked good for break-in oil.
Pulled the intake and head, #5 runner on the intake was sooty, no holes in the piston, no gouging or scoring on the cylinder walls, combustion chamber looks good, no cracks, valves look good and seated. Looked for blow-by evidence on the block deck, head and gasket, all looked good.
Upon removal of the head, a small bit of water fell into the #5 cylinder, before soaking it up I observed if it leaked past, but nothing.
Oh and yes, the piston does move through its full stroke.
So that’s where I’m at, and I am stumped.
Any and all help is greatly appreciated,
Gary
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 18, 2006
  • Jun 18, 2006
any chance there is a broken ring? if there is no compression and the valves check out i would have to say try the compression test again but this time put a little oil in the cylinder. If you get a reading then there must be something wrong with those rings.
F
Faolan
  • Jun 18, 2006
I want to try the oil in the cylinder, but could you elaborate on it a bit more?
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Thursday at 6:45 AM
DadLife0724
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
