Compression Question//Head Gaskets
  • Thread starter Thread starter Smith2450
  • Start date Start date Apr 4, 2005
Smith2450
  • Apr 4, 2005
Okay, Kinda new at this guys, but im doing a head gasket change on a 87 5.0 the engine is tweaked out, with vortech blower msd, exhuast, heads, etc.. the commons n such.. well.. before i noticed the gaskets on the heads were bad, i was noticing a chug, or seemed like misses, if i took the car up to about 2500 rpms, and when i would stop at lights and such, sometimes it would start to rev down to like 300 or so, and jump up to like 1100 or so, i have a
E303 cam but i never did that.. could that of been the gaskets going bad causin compression to mess up? Any replys would be most appreciated thanx guys...
T
TheUser
1,859
Springfield, MO
Apr 5, 2005
  • Apr 5, 2005
http://www.muscularmustangs.com/iac.html
Check out that site and follow instructions. See if that fixes your "surging idle" at the stop lights.
As for your "misses," kinda sounds like either your timing is off or isn't set appropriately for your combo
How many pounds of boost are you pushing? What degree of timing are you running? Do you have a boost retard? What octane of fuel are you running?
I'd bet the gaskets blew at one time instead of gradually over time.
Smith2450
  • Apr 5, 2005
Thanx, i checked that website out and im gonna follow that procedure, as for the "missin" the weird thing is tho, once i changed my plugs and finally got the gap about as close to perfect as possible it went away for awhile.. but then came back again.. carbon build up? As for the blower, pulls like 7 to 10 psi timin shouldnt be bad on it.. carbon build up might be a issue tho i have to deal with.. Any ideas on where i can find all the gaskets im gonna have to replace and what brand i should go with? I need some heavy duty ones so no cheap o's. Thanx for the reply tho
Rick 91GT
Mustang Master
95
99
PA
Apr 5, 2005
  • Apr 5, 2005
The Fel-Pro 10111 should work fine for the heads (assuming they are alum), I know guys that have made 25psi on the stock replacement...it is all in the tune.
The block and heads would need to be machined/ground for a MLS style gasket, then instead of blowing the gasket you break valve train, burn pistons and holes in the head.
T
TheUser
1,859
Springfield, MO
Apr 6, 2005
  • Apr 6, 2005
You know that you retard your timing when running boost right? Probably should have it at like 8* or something. Maybe your blower is blowing your spark out causing the missing problems. I know that's sometimes a problem if you gap them w/ the stock gap. Maybe they conduct better when new and then when they get a few miles on them, they don't conduct as well Maybe it is carbon buildup? Pull them and see...
Smith2450
  • Apr 6, 2005
Reply to the timing
Okay i do have a Boost Retard, Its just alil box with a knob i can turn.. problem is, i only have 0 1 2 3 and 4.. usually sits right above 1 at like 1100 or 1200.. i dont ever notice a difference when i turn the knob tho.. so 8 is way out of the question.. What im stuck on now trying to change head gaskets is trying to get the lower manifold off.. its a edlebrok mani, pretty common one for mustangs ive been seein.. there is a plug i think in the back of it on the driver's side.. i took that plug off and under it was lots of anti freeze, that common? BTW Im only 20, haha and this is the first big project ive done on a engine before, So i have many questions. Since im going to Wyotech it would make sense to start now with learning about my engine. Im also afraid of taking the springs, rocker arms and stuff off, because im not sure how exactly they go back on.. So any websites or manuals or anything would be very helpful with all that... Cant think of anything else right now to say.. but keep the replys coming please.. Thanx
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
