i spun a rod bearing in my old motor ad replaced it with a salvage yard motor till i got my stroker finished. the salvage motor smokes under hard acceleration only. i did a compression test and then realized that i don,t know what the #'s should be. i am over 130#s on each cylinder. if that is good compression then i know it just needs new heads which i have. so guys the question is are these good compression #s?
