compression questions
lineumup88
23
hampton va
i spun a rod bearing in my old motor ad replaced it with a salvage yard motor till i got my stroker finished. the salvage motor smokes under hard acceleration only. i did a compression test and then realized that i don,t know what the #'s should be. i am over 130#s on each cylinder. if that is good compression then i know it just needs new heads which i have. so guys the question is are these good compression #s?
I believe I have read that a stock 5.0L's dynamic compression usually gives in the 150-160 psi range in real good condition.
Those numbers seem pretty good to me for a salvage motor that "smokes."
Somebody may step in and correct my numbers...
130 is low but as long as they are all even it should be fine. Sometimes it will tell you things that a compression test wont. The process you use to take compression can have as much of an effect of the results as the condition of the engine. Unless you have one really low hole or one really high hole all you want is a good even reading. There are times where compression can be great but a broken oil ring can cause an engine to smoke. Old valve guide seals can also cause smoke problems. If you have access to a lead down tester you might try that also. A leak down test well tell you a lot also.
For stock compression, 130 is low on an old engine?
You would know, if anyone...
Yes on a later 5.0L that is stock, 130 is getting down there. It won't hurt anything and it will run fine on that. Unlike the older engines newer engines don't tend to drop in compression as the mileage gets higher. You will however see a drastic rise in leak. :nice:
A general rule of thumb for compression is at least 90-100 PSI. I have seen engines with as little as 50 PSI run as long as all cylinders are about the same. As someone else mentioned when you are doing a compression test you are testing the compression rings not the oil control ring. So you could have good compression but the oil control ring(s) are bad.
When you did the compression test did you have the throttle plate all the way open? Did you take all the plugs out?
