Compression #'s
stevesLX
373
cincinnati
Well I did a compression test and every cylinder was at 150 even with oil. Something I did notice was on cylinder 4 the pressure shot right up to 150 and then it backed down to aroung 142. A couple others shot to 160 and then backed down to 150 and held steady. I performed the test because I just had head work done (3 angle valve job) and lower end done at machine shop and ever since I got it back together I have had valvetrain noise. The machine shop says I might have a bent valve or so seeing that I had a bent push rod after I installed roller rockers the valve covers are to small they were hitting them. So So they told me to do a compression test. Although they wanted me to loosen up the rockers when I did it but I didn't do that just due to the fact I was told that if all my cylinders are pretty well close within one another which they are I shouldn't have a bent valve anywhere. Some more insight on this would be appreciated.
