Compression Test/Coolant Leak
  • Thread starter Thread starter RangerJoe
  • Start date Start date Feb 27, 2011
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Feb 27, 2011
  • Feb 27, 2011
Ok, here is a long post. Just built new 331 stroker. Block was decked and heads were milled .015 for clean up (iron gt40). Compression is about 10.15:1. Edelbrock Performer Intake.
Motor has not been broken in yet. It has been cranked up about 5 or 6 times, ran for a total of probably 20-25 minutes trying to work out idle and such so it could be driven. Noticed small puddles at exhaust pipes, watched for a little while and realized that it was more than condensation. Pulled upper intake, it looked like I was dripping antifreeze into the end cylinders. Pulled intake, re-installed, bigger puddles. Went back, redid gaskets with red gasket maker around coolant ports, changed oil. I haven't tried to restart it yet and see if it still leaks.
I ran a compression test on the cylinders and a compression test on the coolant system. I pumped the coolant system up to 16#. After about 20 minutes it falls about 1#. I don't see coolant in the intake runners (I have the upper intake off at the moment). I have found a few leaks in hoses, etc, been fixing them as I go.
My compression test are crappy. I can't get more than about 25# on any cylinder with the dry test, and with the wet test I get about 50#. Is this normal? I know the rings are not set to the bore walls yet, but would it let this much by?
Intake is torqued to 25# in the "proper" sequence. I did compression test with plugs out of heads.
Any ideas?
Thanks
RangerJoe
2,560
1,146
184
Georgia
Mar 1, 2011
  • Mar 1, 2011
Update
Well, I hoped that I would have recieved some replies to my post. I did figure out what was wrong...it wasn't the car. I guess ingnorance falls to me. I had never actually done a compression test before, so I didn't realize that you had to use the starter. I was turning the motor over by hand with a wrench. Come to find out, that doesn't work. So compression is fine. I thought I would update this post in case someone else came across it in a search.
Thanks to any who took the time to read it.
ID89GT
1,659
18
49
Spokane Valley, WA
Mar 1, 2011
  • Mar 1, 2011
Glad you figured it out lol
LarsD
2,680
119
123
Texas
Mar 1, 2011
  • Mar 1, 2011
I would have answered if I had an idea of what your problem was. Ever get all the coolant leaks fixed?
RangerJoe
2,560
1,146
184
Georgia
Mar 2, 2011
  • Mar 2, 2011
I've been working, so I haven't had time to put upper back on and crank it up. However, when I did the cooling system test, I wasn't seeing any coolant in the intake runners. So that is a good sign. I had to torque the lower intake about 8 times before my torque wrench began to click as soon as I turned it. It seemed like everytime I went to torque it, I could get about an 1/8 to a 1/4 of a turn before it clicked. I guess I just didn't let the gaskets compress the first two times. I am going to go over them again with torque wrench before firing it up again. I found a few post where guys were having to torque over and over again before finally reaching correct torque. Hopefully this works!
BYRDPE
1,556
Memphis,Tn.
Mar 3, 2011
  • Mar 3, 2011
this is how i torque my lower also. i actually retorqued it numerous times over a 2 hour lunch break time span. by doing it this way i do not have to remove the upper and retorque.
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
