Fox Saleen 163
bock said:I would crank the motor by jumping the selenoid.... like this you wont trought fuel in for each 8 cyl... you do this with the keys in your pockets..![]()
This is not a bad idea, but only do this if you are comfortable doing so and make sure the car is out of gear!
Also, I've HEARD that holding the throttle wide open actually cuts off the fuel. And since you do a compression check with the throttle wide open, it would take care of that. But like I said, I'm not sure of this. Anyone?
