Compression Test Numbers
FastSVO
194
Los Angeles
Hey guys,
I have a 91 GT with 57k original miles and just performed a compression test. Here are the numbers:
CYL
1 149
2 150
3 145
4 145
5 150
6 149
7 145
8 149
I was using a cheap tester from Harbor Freight so the darn could not be 100% accurate. In any case, aren't these numbers a little low?
The motor is bone stock except for a GT40 intake and 1.7 rockers. Could the rockers high ratio be causing the low the compression numbers?
Thanks for the help.
-Eric
Is the compression supposed to be tested with the engine warm or cold? Does Ford give a recommended rate for warm vs cold?
Dave
Hot engine, especially if you use forged slugs (which fit the bores looser when cold than a hypereutectic piston would).
I have read that you have to give it full throttle when cranking the motor over during a compression test. Anyone know why this is?
Dave
It's easier to get air into the chambers if there's not a huge impediment in the way (throttle blade). It also should shut off the injectors (backfire concerns).
