  • 1994 - 1995 Specific Tech
compression test results
  • Thread starter Thread starter smigle
  • Start date Start date Oct 27, 2004
smigle
36
Reisterstown, Md
Oct 27, 2004
  • Oct 27, 2004
I had my local mechanic do a compression test and all numbers were from 150-153. Is this considered to be a good compression? Do you know what the stock compression is for my car? I have svt mustang cobra and couldnt find any stock #'s. i had the compression test done to see why i have been burning 1/2quart every 1000-1200miles. No leaks. what could be the problem? Should i be worried about the oil consumption. I use mobil 1 10w30 synthetic. Would switching back to regular oil help? Any help is appreciated.
blksn955.o
3,263
st.louis mo 314
Oct 27, 2004
  • Oct 27, 2004
It may be valve seals as they would not show up on a comp. test as the valves are closed at this point/kind of test.
HISSIN50
34
129
Oct 27, 2004
  • Oct 27, 2004
ummm. ok.
a compression test, like dyno results, is good for relative comparisons. there are enough variances in method that it is just a rough guide. the numbers being so close is what you are lookin for.
if your mechanic had done a wet compression test, that would have helped show the source of any leakage. with numbers like yours, i would not worry.
as BlkSN suggested, a leakdown test can be more precise, but a comp. test does show pressures and the wet portion helps eliminate sources of leakage.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
2K
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
