Compression Test Results
  • Thread starter Thread starter fost9508
  • Start date Start date Nov 16, 2004
F
fost9508
131
  • Nov 16, 2004
I did a compression test on all eight of my cylinders the other day. The results seemed fairly high. I have an 88GT 5.0. All the tests are dry test.
EDIT: I guess formating does not carry over in the forum. the fist number is the cylinder, the second number is the compression on the first stroke, and the third number is the final compression reading after multiple strokes.
Cylinder # 1st Stroke (psi) Final (psi)
1 120 180
2 120 180
3 120 180
4 120 185
5 120 185
6 120 190
7 120 185
8 120 190
Let me know what you guys think.
Thanks
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 16, 2004
  • Nov 16, 2004
perfect #, now start modding the car because you have plenty on life in her.
bgjohnson
963
johnston,iowa
Nov 16, 2004
  • Nov 16, 2004
that's perfect man, and that's a dry test. woot!!
F
fost9508
131
  • Nov 16, 2004
Thanks for the input guys...that is reasuring, at least the block, rings, valve etc...are presumably in good condition. The car still runs like crap though. I think it has to do with the multitude of sensor in the damn thing. The next sensor I am going to check is the ECT. I have heard that sensor can be tied to poor gas mileage. The just seems a little slugish in all rpms except like 3500. After that sometimes it either hisitates or misses. Dunno....I did just replace the plugs in it though...installed bosch 4's. Spose I will repace the plugs cap and rotor also.
Thank again guys.
HISSIN50
34
129
Nov 16, 2004
  • Nov 16, 2004
numbers look great. i dont look at the absolute number so much as the relative numbers - there are enough variances in methodology to create deviation (you and i could check the same motor and get different results because we have different methods).
however, your numbers are smokin.
keep pulling codes and checkin sensors - JR has posted ECT and ACT values before in here if ya need them.
good luck.
jeffnoel
1,638
Clovis, CA
Nov 17, 2004
  • Nov 17, 2004
fost9508, how many miles on that motor?
F
fost9508
131
  • Nov 17, 2004
the car has about 120 k on it. I have heard high compression readings can be due to carbon build up??????? Is this possible?
Thanks
87stang205
26
  • Nov 17, 2004
Carbon build up can definetly cause a High compression number.
F
fost9508
131
  • Nov 17, 2004
what is the best way to determin whether or not I have carbon build up in the cylinders????? I did remove the TB and upper intake and they had quite a bit of carbon build up on them. So I don't know what to do now.
thanks,
F
fost9508
131
#10
  • Nov 17, 2004
  • #10
Asumming I have carbon desposits in the cylinder, is there a product I can buy that I can dump in the gas tank or somewhere to remove the carbon???? Also, would me compression results be as consitant as they are if I had carbon deposits????
Thanks for the help guys!!!
HISSIN50
34
129
Nov 17, 2004
#11
  • Nov 17, 2004
  • #11
yep, deposits can artificially raise the CR. they can also lead to preignition
one of the products out there is Seafoam. i have not used it, but many have and had good results. i am leary of such products and would not use them on a motor which is operating alright (i have read a few horror stories too - but dont know if it was operator error).
the deposits would likely have very little effect on compression results (no discernable difference in your testing).
if you are not pinging or seeing some sort of issue, i personally would leave well enough alone. carbon deposits are normal on about any motor.
good luck.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
Resolved Code 70?? KOEO
  • 5.0-5MT
  • Jun 23, 2024
2K
Fox 5.0 Mustang Tech Aug 6, 2024
General karthief
L
Engine Normal Leakdown Results (unstarted in nearly 2 years)
  • Lube
  • May 26, 2024
Fox 5.0 Mustang Tech Jun 1, 2024
Blackhawkxx
