Compression Test Results ?
  • Thread starter Thread starter Deleted member 87397
  • Start date Start date Oct 21, 2006
D
Oct 21, 2006
  • Oct 21, 2006
Well I'm dying to get my top end kit put on, but I thought I'd do a compression test today to see what shape my rings are in. Engine is 1986 stock internals with 58K on the clock.
All cylinders were between 150 and 160.
I did the oil squirt test only on a couple that I've suspected lately of having problems and the reading went up 15-20 max which I thought was not too terrible, but I could be wrong.
My main question is this: The book says "compression should build quickly. If the reading after the first compression is low and then compression builds slowly on successive compressions then worn rings are likely" I want to know what is considered a low reading on the first compression? All cylinders I tested jumped to about 100 psi on the first compression and took about 3-4 additional strokes to reach max. So, does this sound normal or does is sound like my rings are worn.
Fett
766
  • Oct 21, 2006
I always thought that as long as the cylinders were all within 15% of each other, then they are good results. I too would be interested in seeing what exactly would be a "low" reading.
D
Oct 21, 2006
  • Oct 21, 2006
bump. Someone has to have some input on this.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
