  • 1994 - 1995 Specific Tech
compression?
  • Thread starter Thread starter btracer02
  • Start date Start date Jan 7, 2004
btracer02
146
coatesville, PA
Jan 7, 2004
  • Jan 7, 2004
if i do a compression check on my car (95 gt) what numbers should i be lookin for and how long should pressure hold when i check it?? thanx
xsivpwr
373
kankakee, il
Jan 8, 2004
  • Jan 8, 2004
Id like to know this too...
TTT for you!
cjones
1,561
Avondale, AZ
Jan 9, 2004
  • Jan 9, 2004
a minimum of 135. the highest and lowest should be within 15% of each other.
when you do the check make sure the engine is warm (if possible), remove ALL the spark plugs, throttle at WOT(Wide Open Throttle) and hit the compression stroke of each cylinder the same # of times (about 4 or 5).
the gauge has a valve in it so there is no time limit for holding pressure.
btracer02
146
coatesville, PA
Jan 9, 2004
  • Jan 9, 2004
yea i jsut got sheet tellin me it shoud be between 134 and 250 max psi. i have a sheet that says it should be cranked at about 180rpm and should have no more than 75% variation between cylinders... do stangs typically have week top ends? id hate to buy a car and have to rebuild the top right away so im checkin it anyway
cjones
1,561
Avondale, AZ
Jan 14, 2004
  • Jan 14, 2004
no, normally they're fine.
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
getting 90 PSI at fuel rail - help
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
