compression
  • Thread starter Thread starter 88stangmangt
  • Start date Start date Feb 15, 2004
88stangmangt
2,332
Stafford,VA
Feb 15, 2004
  • Feb 15, 2004
i have a 88gt with less than 70k on it i recently did a compression test on it to see if i was gonna re-build it but i dont think i did it right it cam out more than 10%(i think next i will do a leak down). is it common for rings to go bad in only 69k in our 5.0's???????????????????? i am just gonna put it back together slap a vortech on it and hope for the best. it has been since fall that i have driven it and cant stand it no more!!!!!!!!!!!!!!!!!!! i havnt heard my flows in about 3 months!!!!!!!!!!!!!!!!!! im dieing.
88stangmangt
2,332
Stafford,VA
Feb 15, 2004
  • Feb 15, 2004
^^^^^^^^^^^^^NUMBER 302!!!!!!!!!!!!!!!!!!!!!! hell ya!!!!!!!!!!
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Feb 15, 2004
  • Feb 15, 2004
Cam out? The valvetrain needs to be working for a proper compression check. How is air going to get in there and get compressed w/o the cam in the engine.
88stangmangt
2,332
Stafford,VA
Feb 15, 2004
  • Feb 15, 2004
no it is all still in and together long tubes/throttle body/wires and all that crap are off but everything is still on. And it runs strong!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! so i think i will try my luck.
fly4spd
118
Las Vegas & Reno
Feb 15, 2004
  • Feb 15, 2004
when he said "cam out", he meant "came out", it looks like
T
TheUser
1,859
Springfield, MO
Feb 15, 2004
  • Feb 15, 2004
I won't say it's the best idea, but i'm doing the same thing lol so...except I got one cyclinder pushing like 40 psi and the rest are 125-150
J
jerry beach
2,671
Ocala,FL
Feb 15, 2004
  • Feb 15, 2004
That is not a good plan, think about it.
88stangmangt
2,332
Stafford,VA
Feb 15, 2004
  • Feb 15, 2004
well i know this if there is pepole out there with almost 200k on there block and run great compression and then mine with 69k im gonna be pist!!!!!!!!!!!!!!!!!!!! if i have to re-build
90mustangGT
2,773
17
89
Dallas, GA
Feb 15, 2004
  • Feb 15, 2004
70psi is nessasary for combustion. Yes fuel will burn with less, but to actually combust, it needs that kind of pressure. TheUser: Check that cylinder again, if it still gives you below 70psi, try adding a little oil to the combustion chamber, if it does nothing, you probally have a valve train or head problem, if it rises, you have bad rings most likley.
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 5:48 PM
from6to8
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
