  • SN95 4.6L Mustang Tech
Compression
  • Thread starter Thread starter jasonh_86
  • Start date Start date Sep 20, 2005
jasonh_86
I
May 20, 2005
1,156
Arkansas
Sep 20, 2005
  • Sep 20, 2005
What is the compression in a stock '02 GT motor? and how do u reduce the compression?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Sep 20, 2005
  • Sep 20, 2005
it should be 9.4 - 9.6 cant really remember but get a deeper dish to lower the compression ratio
jasonh_86
I
May 20, 2005
1,156
Arkansas
Sep 20, 2005
  • Sep 20, 2005
so, to lower the compression to 8.1 u just get dished pistons and the forged internals to go with them?
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Sep 20, 2005
  • Sep 20, 2005
change the pistons or get a thicker headgasket. you could also get your heads worked on to lower compression, but i wouldn't advise it.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Sep 20, 2005
  • Sep 20, 2005
are you going FI because if you are then yeah lower your CR but if not i dont really see why?
sgarlic
3,085
Sep 20, 2005
  • Sep 20, 2005
The answer to your first question is 9.4:1.
I'm curious as to why you'd want to lower your compression ratio? If you have a pigning problem, use better gas or change cams.
R
RedGTvert
3,129
Wellington, FL
Sep 21, 2005
  • Sep 21, 2005
Even with FI, there is absolutely no reason to go with 8.0:1, unless you are putting a big thumper on there.
Stick with 9.0:1 and you'll be fine under most FI applications.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Sep 21, 2005
  • Sep 21, 2005
yeah thats true stick with 9.0..........aint the 03 cobra C/R 9.0:1
jasonh_86
I
May 20, 2005
1,156
Arkansas
Sep 21, 2005
  • Sep 21, 2005
I was just wondering, because I thought I read somewhere that for a TT setup or KB 2.2 that it'd help to get lower compression to keep the motor from going BOOM!.. But maybe i'm wrong, i'm no genius haha
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Sep 21, 2005
#10
  • Sep 21, 2005
  • #10
you can keep the stock compresion but just swap out the internals with forged internals and once you add what ever poweradder just get a real good tune and you'll be ok
jasonh_86
I
May 20, 2005
1,156
Arkansas
Sep 21, 2005
#11
  • Sep 21, 2005
  • #11
alright.. that sounds good to me. I just wondered about it because a buddy of mine who drag races as a hobby said that dished pistons would be best for motors with boost on them, especially turbos..
hotmustang331
2,967
Bastrop,TX
Sep 21, 2005
#12
  • Sep 21, 2005
  • #12
Your consern if you went with a 2.2 KB or TT would be the ENTIRE rotating assembly. The 03 cobra has 8.5-1 C and thats a good idea when you get a big blower like that. Be advised that you going to spend a BUTT LOAD of cash. 5K just for the KB, $3500 for the shortblock, alot of $$$ for the new fuel system, beefing up the car with things such as SFCs, clutch, than you got the tune for the whole thing as well as installation. Over 13K for everything. for the 2.2. WELL over 15 for the TT setup.
There are more things that would be needed before you run slicks at the track, like new tranny, new rear axle, welding torque boxes, roll bar or cage. Its VERY expencive....you should do like me and plan this stuff out and buy things a little at a time.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Sep 21, 2005
#13
  • Sep 21, 2005
  • #13
well said take your time and think it through
billfisher
1,296
huntsville, AL
Sep 21, 2005
#14
  • Sep 21, 2005
  • #14
with today's engine management and intercooler technology it wastes 14% of your power for each point you drop. you just need the real deal. KB seems to have a complete approach. 8.0 is old school.
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
D
AOD TV cable replacement bushing - loose pin?
  • DuluthFoxbody
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2026
DuluthFoxbody
D
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
