  • 1994 - 1995 Specific Tech
Computer code 543
  • Thread starter Thread starter callys
  • Start date Start date Apr 29, 2006
callys
76
  • Apr 29, 2006
I have a 1994 5.0 and my 02 sensors were bad so i replaced them then i scanned the computer to see if the bank 1 and 2 lean codes were gone, and they were. However, while running the engine on test i got engine code 543 which basically says there is an open connection between the fuel pump and the battery. Thing that is really pissing me off is I didnt touch anything else. I jacked up the car, replaced the sensors, put the car down, ran the test. Does part of the fuel pump relay run through the O2s? I checked all the fuses in the engine compartment fuel box and they all came out fine. The even weirder thing is the car started at first and ran then gave me the code and then it wouldnt start.
Any suggestions at all? Otherwise I guess I have to get it towed to an electrical shop.
edit - I read the 543 diagnostics write up, I will try putting in one of the old o2 sensors on the left side.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Apr 29, 2006
  • Apr 29, 2006
You didn't say if you cleared all the codes or not. Clear all of they if you haven't do so already.
HISSIN50
34
129
Apr 29, 2006
  • Apr 29, 2006
So after doing lambdas, the car wont start? You're smart to look for a short. IIRC, if the lambda shorts out, it triggers a secondary fuel code. Look for bad wiring and pins while checking things out. The connectors can get corroded or just oily.
Good luck.
callys
76
  • Apr 29, 2006
I tried replacing the left O2 sensor and I checked out the pins on both male and female connectors several times... I dont see anything wrong. I guess I will have to try to trace the wires all the way up.
Wystang how would I go about clearing the codes? I don't have an aftermarket tuner, I just have an EEC reader. Do you mean just reseting the computer?
Right now the fuel pump will not come on at all. I turn the key forward and get nothing (no hum)
I guess I will end up taking the wrapping off the trail of wires that snakes up the front of the engine and looking for something torn or shorting
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Apr 29, 2006
  • Apr 29, 2006
Yeah just resetting the computer, disconnect the batt for about 10min that will clear the codes.
HISSIN50
34
129
Apr 29, 2006
  • Apr 29, 2006
What happened if you disconnected both O2 wiring harness connections? It is possible to get a bad or wrong O2 and have it cause an issue.
IIRC there's a fuel pump fuse - I would check it real quick and make sure it didnt blow due to the ancillary issue.
Good luck.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 30, 2006
  • Apr 30, 2006
does the fuel pump cycle when you turn the key to acc???
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
