computer diagnostic question
  • Thread starter Thread starter Roadblock
  • Start date Start date Apr 12, 2005
Roadblock
208
VA
Apr 12, 2005
  • Apr 12, 2005
ok i have taken out my dash, in an effort to redo my entire interior and gut out some stuff like a/c ect....anyway i have fuel i have fire, but she dont start i wanted to kno if the dang computer hadgotten messed up so i went a tried to do the check engine thing, i pulled out my lil tester connected it and turned on the key, and switched her to test and she never stopped maki8ng her whinning noise she didnt start to beep or anything....does this mean my puter if fried, or is it that i dont have something connected?
I
Insane3D
310
  • Apr 12, 2005
Keeps whining? Could that be your fuel pump constantly running? I think if you floor the gas pedal while cranking, it will cut out the injector pulse and clear a flood condition. Give that a shot.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 12, 2005
  • Apr 12, 2005
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set emergency brake. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if present.
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the black 10 pin connector.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
Roadblock
208
VA
Apr 12, 2005
  • Apr 12, 2005
ok well i searched before i posted so thx for what i had already read...lol....anyway check this out it startsand runns now but the mass air flow has nothing to do wiht it its starts and run w/o the maf hooked up at all
idles fine and revs great
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
  • dan50
  • Jul 18, 2026
dan50
Computer repair advise
  • sammie9271
  • Jul 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2025
Parauno
P
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
