Computer Failing?
  • Thread starter Thread starter slow5.0gt
  • Start date Start date Oct 14, 2007
slow5.0gt
138
  • Oct 14, 2007
Strangest thing, upon startup of 90 5.0 the car is at a very low idle eventually just dies. I check tps/iac (both of them pretty new). I get the base idle corrected to around 700 rpm. Idles great no surging nothing like that.
Turn off car I make sure the TPS around .98 volts. Plug in spout and IAC,try starting it up and its back down to 400 rpm again.
I can step on the gas and it will rev up quickly no hestiation but idle is the problem too low before dying wasnt exactly surging I checked jrichers list and did what I could off the bat.
But what I think is weird is that it seems to lose the idle setting after getting it corrected once I turn it off and start it back up.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 15, 2007
  • Oct 15, 2007
Did you get any codes?
Once the mechanical base idle is correctly set, the engine's idle speed should not drop below that point. The IAC can only add air to increase the idle speed. It cannot take away air to reduce the idle speed below the mechanical base idle.
slow5.0gt
138
  • Oct 15, 2007
I did try and pull codes I got nothing but the smog and air stuff with KOEO but unable to pull codes with KOER. Just searchs and searchs and nothing, or the car dies before im able to get my foot on the gas to keep it up.
slow5.0gt
138
  • Oct 15, 2007
Thats whats weird why does the idle change after me setting the base idle and everything? Cant figure out why it does that
M
Mike85000
65
  • Oct 15, 2007
I would suspect that possibly your smog codes could play a role if your EGR valve is stuck open or something of that nature. If you are getting too much exhaust gas at an idle the mixture may be so screwed that it chokes out the motor.
Just a thought...
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
