How much would cost to get my computer reflashed for a gear swap? Would it be cheaper than buying a programmer or a chip? I want to get gears but I have a auto and it's expensive because of the electronics in envolved.
He may be able to help you out. I was one of the first to go with the Steeda N/A ECU reflash to calibrate for my 3.73's, but if you want 4.10's or higher Steeda won't do it. I believe for 4.10's or other ratio's, Tim can reflash the ECU for you instead using another software package. My reflash with gears cost around $439 if I can remember.
There are other benefits of the ECU reflash, not only will they correct the speedo for gears, they also replace the need for a timing adjuster. The reflash advances timing and fuel rates automatically depending on outside conditions (complete adaptability).
